Need Source for Heat Resistant Paint > 300 deg F
Can anybody help?
I need to find a source for heat resistant paint in different colors. I need at least brown- but yellow, orange, red, blue, and white would be awesome. I'm not sure what temp it has to go up to, but 300 F is a good guess.
Oh yeah, I need it in a hurry too.
Adam s [surname deleted for privacy by Editor]
- Pasadena, California
Adam - any luck? - I'm doing the same research for White Heat Paint (for radiators).
Please let me know if you found any leads (sorry I couldn't help).
PB
Peter B [surname deleted for privacy by Editor]
- Staten Island, New York
I too am looking for such a paint. Any luck?
Pamela H [surname deleted for privacy by Editor]
- Toronto, Ontario, Canada
Any luck on the search? This site came up when I googled on white heat-resistant paint. I also found Chase Product High Heat White Spray Enamel but no luck on where to buy it yet. Any leads are appreciated.
Jens L [surname deleted for privacy by Editor]
- Brooklyn, New York
JCWhitney has a product with multiple colors that resists heat up to 900 degrees F. I believe the name of the product is "Brake Drum and Rotor and Caliper Paint".
I believe you can order two spray cans that each have 11 ounces of product in them. I hope this helps if you all are still looking for heat resistant paint.
Dave [surname deleted for privacy by Editor]
- Janesville, Wisconsin
Try a place call Exotic Flames, They have 3 different whites and green, tan, red, black. You can google them.
Angie Hansen
- Meridian, Idaho
High Heat 2000 Degree Spray Paint, Flat Aluminum
Hi-Temp Red Paint
Krylon High Heat & Radiator Spray Paint, White
Adam, 300 deg isn't really "high heat" as paints go; many are rated to 1200 deg. and more.
Peter, Pamela, I've used regular interior house paint on radiators with no problems. They are unlikely to even reach 212 deg (boiling point of water).
Jens, Chase Products has a website where you can buy it online.
Dave, Angie, thanks.
You can buy high temperature paint on line from Amazon, as seen in the listings to the right. Good luck all.
Hi everyone,
please check this Akzo Nobel Intertherm 228, its a white paint and withstands 230 °C / 446 deg. faren..
alternatively there is this Berger make primer (grey colour) that can withstand a temperature of 300 °C..
hope the above serves your purpose,
take care cya
Harshal Chavan
- Mumbai, India
October 28, 2009
