Rainbowing on bright decorative anodising
I have a small anodising operation and am experiencing difficulties with one particular component which is highly decorative and has a high level of brightness. The product is manufactured from 1mm sheet and is pressed into a slight curved profile. The part is then polished prior to anodising. I employ all the standard pre treatments degrease, caustic dip, desmut and then an electrolytic brightener. The problem I am having is that I am getting a slight rainbowing on the part which looks like low thickness but upon measurement the thickness is steady at 6-7 microns. I am at a loss to know what is causing this and would be open to any suggestions.
Bill T [surname deleted for privacy by Editor]- Offaly, Ireland
Rainbow is caused by an interference of the light reflection. The non random polish marks are probably just small enough to give the interference.On a scrap part, try etching it longer and see if that makes a difference. Or try less time in the electrobrightener step.
James Watts- Navarre, Florida
