Ionic load calculation of ion exchange unit
Is there any ready made programme available which can calculate the
1. Total ionic load
2. Max output we can get from exchanger
3. qty of chemical reqd for regn
For ion exchange units where in we can feed input data like
resin qty,type, water analysis,bed depth, type of regn ( co / counter )
chemical strength and any other data taht may be reqd to calculate.
Vasudevan P
plant manager - Chennai, Tamilnadu, India
The companies that you get quotes from will be happy to provide you this information and more, if they want to make a sale.
Go to the Dow Chemical web site and download the CADIX program. This is free for use. It will be of great help to you. The only factor you have to be careful of is that you do all your calculations on basis of DOWEX Resin characteristics and properties.
On basis of cost/performance, BAYER'S LEWATIT is preferable. You must be careful that resin properties may not give you a really accurate solution, but the results though approximate will work within working parameters.
Ahmed Soorma
- Karachi, Pakistan
