Thread 338/94
Friction problem in nickel plating parts
DEAR READERS,
I AM DEVELOPING A HINGE TYPE COMPONENT. THESE ARE TWO 1.5 MM THICK MILD STEEL BARREL NICKEL PLATED 11 X 90 MM STRIP PIECES. HAS A HOLE IN EACH STRIP END & BOTH ARE JOINED THROUGH A NICKEL PLATED RIVET. JOINT IS NEITHER VERY TIGHT NOR LOOSE SO THAT WE CAN MOVE THE ASSEMBLED PART. AFTER RIVETING WHEN WE START ROTATING' AFTER A FEW ROTATION IT GETS JAM DUE TO REMOVAL OF NICKEL & SCRATCHES IN THE AREA WHICH ARE FACING EACH OTHER. please TELL HOW WE CAN SOLVE THIS. AS WHEN I USE SOME OIL OR GREASE IN THAT AREA IT WORKS WELL. WILL I HAVE TO USE OIL & GREASE AS A MUST? OR IS THERE ANY OTHER WAY ALSO. please REPLY.
- KANPUR, U.P., India
publicly reply to NAVED AHMAD
Plate at least one surface using electroless nickel phosphorus. Nickel against nickel will almost always gall. but electroless NiP does not gall. You could use ENP on both surfaces. ![]() Don Baudrand Consultant - Poulsbo, Washington (Don is co-author of "Plating on Plastics" [on Amazon or AbeBooks affil links] and "Plating ABS Plastics" [on Amazon or eBay or AbeBooks affil links]) publicly reply to Don Baudrand A. >Naved ![]() Asif Nurie [deceased] [deceased] - New Delhi, India With deep sadness we acknowledge the passing of Asif on Jan 24, 2016 publicly reply to Asif Nurie [deceased] A. Hi Naved - Colorado Springs, Colorado, USA publicly reply to Jeff Marten A. Nickel against nickel is like stainless steel, it will gall, IE: it will try to cold weld together. If there is a heavy load or if the load is mild, but, with a frequent motion, nickel is a poor choice. Lubrication will be required. You could try electroless nickel plating the smaller of the two parts and see if that will work. James Watts- Navarre, Florida publicly reply to James Watts |
