Galvanizing process for blind hole
SUGGESTED GALVANIZING BOOKS
for Engineers, Shops, Specifiers
galv_structures2016
"Hot Dip Galvanizing of Steel Structures" by Kuklik & Kudlacek (2016)
galv_hot_dip_handbook2011
"Handbook of Hot Dip Galvanization" by Maass & Peissker (2011)
galv_and_concrete2004
"Galvanized Steel Reinforcement in Concrete" by Stephen Yeomans (2004)
galv_practice_hornsby1995
"Hot Dip Galvanizing -- A Guide to Process Selection & Galvanizing Practice" by M. J. Hornsby (1995)
"Faults in Hot-Dip Galvanizing" by Dietrich Horstmann (in English, French & German)
avail from Amazon
"User's Guide to Hot Dip Galvanizing for Corrosion Protection in Atmospheric Service" by NACE (1997 only rarely avail.)
Our part: 1" round bar X 6.5" long with a blind hole (1/2-13) By 1.25 deep on one end.
I need this galvanized for corrosion purposes... How can we do this with out venting or drilling a hole through the complete part?
Todd Cardiff
- Hayward, California, USA
The type of product you are galvanizing has a couple of options, depending on the quantities you have. If there are not too many pieces involved, and the holes are already drilled & tapped, you can insert a bolt with high temp. anti-cease. Make sure the bolt is snug but not extremely tight. After dipping, the bolt can be simply removed. If you are manufacturing these parts regularly, I would look at drilling & tapping post galv.. The threads will normally not be galvanized on the i.d. anyway. The part is small enough to handle either way.
David Jaye
Houston, Texas
