Cast 17-4 material does not passivate well
Quickstart: Investment cast parts are difficult to passivate, but it can be done with citric acid solutions. However, passivation should not be done until after heat treatment.
www.finishing.com is made possible by supporting advertisers ...
Bead Blaster
bead_blaster
Q. We receive cast 17-4 handles from an investment caster. We bead blast the handles to achieve an ok surface finish. If we passivate at that point the handles get a frosty look causing us to bead blast again. But this time the bead blasting gives us a very nice appearance. What is happening to the 17-4 at passivation? They have not been heat treated.
Can I skip passivation after I have bead blasted?
Eric Hubbard
connector products - Waynesboro, Virginia, USA
A. Investment cast 17-4PH parts can be a real problem to get passivated so that they will not corrode and discolor, but it can be done. We have been very successful at many companies in getting the bead blasted parts passive using special citric acid formulations. Standard passivation formulations do not seem to work well normally.
lee kremer
lee kremer sig
Lee Kremer
Stellar Solutions, Inc.
McHenry, Illinois
stellar solutions banner
A. If they haven't been heat treated, they are still in un-useable condition. They do not have the intended mechanical properties or corrosion resistance potential until they have been heat treated. Heat treatment will destroy the effects of passivation, so you should delay passivation until last.
Bill Reynolds
Bill Reynolds [deceased]
