Coumarin in Nickel Watts Bath Solution
I tried to add coumarin & saccharin to Watts Bath Nickel Solution, I faced problem of them. What is an effective way to mix them?
Rio Simbolon
- Jakarta, DKI JAKARTA, Indonesia
What sort of problems?
I boiled coumarin in aquades, first it dilluted but after I filled this solution in to fresh watts bath solution, coumarin solidified as first. any ideas?
Rio Simbolon
- JAKARTA
Coumarin is only very slightly soluble in water (0.25g/100ml), so when you added the hot solution to the cold watts nickel, you exceeded the solublity limit in the cooler solution.
My friend Rio Simbiolon
Using coumarin these days in Nickel plating is not a good idea. It causes the formation of Meliotic acid on breakdown and this causes plating defects. Coumarin went out with the advent of newer additives for Nickel Brightener formulation.
It is possible to obtain these pre blended additives for Nickel brightener blending if commercial activity is your eventual direction.
asif_nurie
Asif Nurie [deceased] [deceased]
- New Delhi, India
Try dissolving coumarin in ethyl alcohol.
Cumarin is out for many years. It is unstable and has a terrible smell of toxic vapor.
sara michaeli
sara michaeli signature
Sara Michaeli
Tel-Aviv-Yafo, Israel
Dear Rio,
Based on my knowledge in nickel plating field for years, coumarine only being used in semi-bright Nickel system and Saccharine only being used in Bright Nickel system. What kind of system that you are going to test or use ?
Best regards,
Tony L. Chandra
- Jakarta, DKI Jaya, Indonesia
