Will cupric sulphate powder plate the same as copper sulphate crystals?
I'm doing a science fair project and I can't find copper sulphate this on eBay or Amazon [affil links] crystals for the solution of electroplating copper onto brass and I would like to know if cupric sulphate powder would work the same as copper sulphate crystals?
Vy T.
student - Houston, Texas, U.S
As a rule, powder is the same as crystals, only finer. As long as you work on a weight basis, the only thing to check is whether or not the cupric sulphate is hydrated (CuSO4 vs CuSO4.5H2O)
James Totter
James Totter, CEF
- Tallahassee, Florida
Cupric sulphate (CuSO4) is the technical name for copper sulphate when the copper is divalent. It is normally hydrated and has a blue colour. If the copper sulphate is monovalent (Cu2SO4) it is unstable and a whitish colour. You can (and should!) use cupric sulphate for copper plating.
Try www.wardsci.com they supply chemicals for use in classroom and science projects. They should have what you are after.
Marc Banks
- Elizabeth City, North Carolina
