Will Zinc plating degrade/damage rubber oil seals?
Is there any compatibly issues with Zinc plating (ASTM B633-85 FE/ZN 5 with Black Chromate) and Nitrile rubber oil seals (NOK TC40627213.5x6Y) i.e. will this type of finish degrade/damage rubber seals? Please advise. TIA!
Jonathan Pryor
Ag - Gainesville, GA, USA
BTW, this involves a metal part (wheel hub) that is powder coated and looking to change it to zinc plating as previously detailed. This part comes into contact with a rubber oil seal on the axle and Im not sure if the zinc plating will degrade/damage the rubber seal.
JP
- USA
