Clarification regarding ASTM B117 Test
Hi,
I am working corrosion resistant paints that are applied on the Induction Motors. I heard that paints are certified based upon ASTM B117--96 hrs test.
Can you please provide, what is salt spray test and how the paints are certified after the test. i.e., any special type of corrosion resistant measurement or based upon the comparison with non exposed material.
Harishankar Rajendran
GE-India Business Center - Hyderabad, Andhra Pradesh, India
Hello Harishankar. What is missing from your question is a specification for the painting. That will include the criteria you are looking for. ASTM B117 says how the salt fog cabinet is designed and operated, but the painting spec says what the pass/fail criteria are.
Please see the entry by Cynthia Meade in topic 21901 where she references some ASTM standards that may help you.
