Stainless steel corrosion rate at high pH?
Is there information on corrosion rate (mils per year)in a stainless steel pipeline at a velocity of 10 ft/s if the pH of the liquid is between 13 and 14. The stainless steels I am interested in are 304L and 316L.
Ramesh Gandhipipeline engineering - Fremont, California, USA
I would definitely talk to the OEM for the pipe as you are talking about something that is a far cry from laboratory errosion.They will probbly be very interested in what the material is and if it has ANY particulate matter in it.
James Watts- Navarre, Florida
The chloride content, acid or alkaline pH, will make a big difference from any tablular data accumulated by a green school boy engineer.
