Hexavalent chromium in stainless steel passivation waters
Is it possible to generate hexavalent chromium in the process of passivating stainless steel (assuming a dichromate solution is not utilized within the nitric acid tank itself)?
Kevin Barrettenvironmental protection - Hartford, CT, US
From what I've been told, Nitric acid passivation (without other ingredients) should NOT result in heavy metals in the rinse water. The addition of HF (or Ammonium Bifluoride) will create a pickling solution and will result in metals in the rinse water.
If others have technical data to support or refute this, I'd be very eager to see it.
Todd Turner- Monroe, Louisiana
I have never heard of this happening and strongly suspect that it doesn't. Although nitric acid is indeed an oxidizing agent, hexavalent chromium is itself a powerful oxidizing agent, and I presume it cannot be created by simply exposing Cr0 or Cr+++ to nitric acid.
