Surface finish symbols
I want to know the surface finish of a component having only one circle in Lay symbol. surface finish is not directly specified in drawing but only one circle is shown.
Yogesh Wad
Trader of machining components - Nasik, Maharashtra, India
I'm not looking at the symbol, so I'm only guessing...
A small circle lying in the "V" area of a "checkmark" symbol means "no material may be removed from this surface". If it's a larger circle and no checkmark is around, it's probably just an item number callout where the draftsperson didn't get back to putting the item number in :-)
