How to achieve required surface finish
Sir,
We are grinding a metal strip of 0.15mm with a wheel of grit 240 .We require a surface finish of .09 Ra.what type of polishing wheel is required?
Thanking you
Sandeep Madan- Faridabad, Haryana, India
The only way to achieve that kind of finish is by lapping your parts
AF Kenton
