Thread 334/64
Stress corrosion cracking of 304L vs. 316
I would like to know about the possibilities of stress-corrosion cracking for SS 304L at following thermal hydraulic conditions:
1. Temperature = 150 deg.centigrade - tube side
2. Chloride presence = 150-160 ppm
3. Service: oil carry over problem with the service gas(which is non corrosive).
Pls. let me know, whether I could use this material or should go for 316SS.
Osama
fertlizer company - Rawalpindi, Punjab, Pakistan
publicly reply to Osama Syed
First of two simultaneous responses -- 2004
No significant difference is susceptibility to SCC between those two grades. If you think SCC might be a problem, you should consider 2205 - more expensive initially, but a whole lot cheaper in the long run when you don't have to replace or repair it.
Bill Reynolds [deceased]
publicly reply to Bill Reynolds
Second of two simultaneous responses -- 2004
Two of the criteria for SCC in stainless steel have been met - temperature over 50, and presence of Chlorides. You don't say if you have already experienced problems, but in my experience you are likely to. I presume the environment is wet - ?
Unfortunately 304 and 316 are both susceptible, 316 with better pitting resistance from 2+% Molybdenum is better (usually) as it can prevent pit initiation.
In our application, we aim to keep Chlorides as low as possible, and reduce stresses as far as possible, with a regular inspection regime to keep failure incidence low.
Best of Luck
Martin Richship repair - Plymouth, UK
publicly reply to Martin Rich
