Protective coating on Ni plated steel
I am trying to put a protective coating on the Ni-plated Steel part. Can I use Iridite or Alodine to coat Ni plated steel part? I know Iridite or Alodine is usually used to coat aluminum part. Does anyone know this?
Andrew ZhangL3 communications Corp. - Rolling Meadows, Illinois, USA
Chromate conversion coatings will not react with nickel plating and will not siginificantly protect it. What do you want to protect the nickel from?
