No passwords, No popups, No cost, No AI:
we earn from 'affiliate link' purchases, making the site possible
Sound technical content, curated with aloha by
Pine Beach, NJ
Removing coating (anodizing) on aluminum motorcycle frame & polishing
     Aluminum is often anodized, which puts a very hard corrosion resistant finish on it. But polishing the anodizing isn't practical; it must be removed before polishing, usually with a strong caustic chemical sometimes by wet sanding.
     If you'd like an "Intro to Anodizing" follow the link; if not, read on ...
Q. I am am trying to polish my frame on my motorcycle, but there is a coat on top of the aluminum. Could someone tell me how to remove this coat with household chemicals. I was told to use Drano ⇦ this on eBay or Amazon [affil links] or Liquid Plumber. So far Drano hasn't really worked. If you have a suggestion please reply and inform me how to remove the coating of my frame. Thanks!
Nguyen Huy
A. If you succeed in removing the anodize so that you can polish the frame, you will want to anodize the part again. You won't be able to do this with Drano, and you won't be happy with a soft aluminum frame, since it will ding easily.
tom & pooky   toms signature
A. I've polished a couple of GSXR frames for myself and customers. By polishing it you're removing the protective coating of the frame. Aluminum actually oxidizes easier and faster than steel, the only difference is that the oxidation actually forms a protective layer thereby prohibiting any further oxidation. Unless you do something to prevent this your frame will turn dull very quickly and you will constantly be polishing it to make it shine. You can overcome this by utilizing some kind of protective coating. Some people use a clear coat to protect their polish. This is probably the easiest way to protect it.
As far as getting the old finish off, just sand it. Start off with 300 or 400 grit paper and work your way up to 1000. At this point you have to start buffing with polishing compound to bring out the shine. This sanding will most likely have to be done by hand so as to avoid swirl marks. Sand in a straight back and forth motion only. You can then use a high speed buffer for polishing. It's very tedious and time consuming but the results can be worth the effort. It takes me about 40 or so hours to do a frame and that doesn't include assembly or disassembly.
Mike Hauke
- Milwaukee, Wisconsin
GSXRs on eBay (affil link)
Mothers Polish
mothers_polish
A. Don't listen to the old ones. If you have a drill and a sanding wheel that has scrubby pad in it, it looks like a small piece of sandpaper and then a piece of scrubby pad on a mandrel. At a low speed you can work with it (in one direction only, or you will mess it up). Then when you get the Alodine^anodizing off, you begin to wet sand. Don't gouge your frame with the drill (very important) or you might be sanding for a while. You can get an assortment of wet paper varying from 320-600 grit. Keep the paper wet, always, with a spray bottle of water. Sand it until it starts to get shiny with water and then polish with Mothers Mag & Aluminum Polish ⇨
If you don't use a good polish it will look bad. Count on polishing it about once every two weeks at the least. I have done two frames, a 94 CBR 900rr and a 98 GSXR 750.
doug abram
Ed. note: Thanks Doug. But don't listen to the new ones when they talk about getting "the Alodine off" though. Alodine (chromate conversion coating) is a totally different process from anodizing and has nothing to do with this thread :-)
A. To remove the factory finish go to your local auto parts store and buy two cans of "Aircraft Striper".
It is very strong so use rubber gloves this on eBay or Amazon [affil links] . After that use 320 grit sandpaper and continue to 1500, wet sanding at 1000-1500. You can use a Black and Decker palm sander ⇦ this on eBay or Amazon [affil links] but sand in the same direction. Be careful not to sand too long in one area so as not to burn the metal. Then use a high rpm buffer this on eBay or Amazon [affil links] along with jeweler's rouge this on eBay or Amazon [affil links] .
criocket morning
- greenville North Carolina
A. Use paint remover, it's quick and easy. Buy the aerosol type for "aluminum" I've done 6 bikes this way and it always works. Then just sand with 400 grit for the final finish.
Peter McMurchy
- Ottawa Canada
Q. I own a 2000 CBRF4 metallic silver/ red, I know it's a lot to ask but I was wondering if anyone can give me a step by step format on how to polish a motorcycle frame? You don't have to give me details on removing parts from the bike--its pretty self explanatory, I would appreciate the steps on taking of the metal protectant and then sanding and whatever comes next. I know you are supposed to change grits, but how do you know when? I've never done this before and I would really like to have this finished for the next riding season.
Thanks to whoever answers in advance.
Orlando Vazquez
- Bartlett, Illinois, USA
A. I have polished several frames and this is what I have found.
Skip the Easy Off oven cleaner or the Aircraft Paint Remover (I have done it this way and it sucks and makes huge mess, WAY too much work too) ... there is no better way to remove the clear coat than a standard drill and a polishing wheel adapter at your local Sears. You will need to buy 5" adhesive backed sandpaper pads for the adapter. Make sure to buy a couple packs of both 100 grit and 220 grit adhesive pads. Your next stop will be at local auto parts superstore and go to the automobile paint isle, buy wet/dry sandpaper in the following grits 400, 600, 800, 1000. Also stop by your local hardware store and pick up a bag of both #00 steel wool this on eBay or Amazon [affil links] and 000 steel wool this on eBay or Amazon [affil links] . You will strip 99% of the clearcoat with the 100 grit pads; try to use the drill in a consistent motion that follows the "grain" of the frame when possible. Progress from 220 grit pads to wet/dry and soapy warm water hand sanding from 400, 600, 800, 1000. During the wet dry phase you should make sure to sand in consistent movement that should follow grain of aluminum, DO NOT BUFF IN CIRCLES.
After the wet dry phase I then move to the #00 steel wool this on eBay or Amazon [affil links] and buff in the same motion with quite a bit of elbow grease, I then progress to the #000 steel wool this on eBay or Amazon [affil links] and do the same thing. If you have done everything properly your frame should look fairly polished at this stage but the final steps will bring out the "ultimate polish" and give you hopefully a mirror like shine that equals chrome plating.
I use a converted angle grinder this on eBay or Amazon [affil links] with the guard removed for this buffing, you can also use a high speed buffer as long as it turns HIGH rpm. Your local Home Depot carries in the tool section a brand of products called DICO, they are in orange/brown packages and they are made for metal finishing. You will need to buy two buffing wheels, make sure to buy the ones that are very tightly stitched together as you will want to apply pressure to the frame with the wheel, the loose buffing wheels will not work the way you need them to. You will also need to buy a stick of EMERY ROUGE this on eBay or Amazon [affil links] , TRIPOLI ROUGE this on eBay or Amazon [affil links] , and for optional last step you may want to buy jewelers rouge this on eBay or Amazon [affil links] (and a 3rd buffing wheel if you buy a third stick of rouge). Fire up your buffing wheel and apply EMERY rouge to wheel, polish the frame in consistent movement, reapply rouge as necessary, progress to TRIPOLI rouge and fresh buffing wheel and then finally JEWELER'S ROUGE with a fresh wheel. DO NOT MIX rouges of different types on the same wheel, you will get inconsistent results. I use Mothers Alum. Polish this on eBay or Amazon [affil links] for maintenance but occasionally will pull out buffer and give frame/swingarm a quick hit with EMERY rouge.
If you follow these steps you will be thrilled with result. It sounds like a lot of steps but if done properly it won't take as long as you think. I polished the frame of my R1 in day and a half, if removed from the bike the whole swingarm could be done in a weekend or less. I have also found different frames respond differently to different buffing rouges...for example the 93 GSX-R and 95 900rr frames that I polished responded very well to the TRIPOLI rouge, however on my R1 the Tripoli rouge made the frame look like sh*t. The basic steps I have outlined are necessary on any make frame, the very final finishing stages may vary a bit from bike to bike as I have found. This is THE WAY to do this correctly in my opinion, do not believe there is any big secret shortcut - polishing frame is big commitment. The biggest thing I have learned is using the drill and polishing adapter to strip the clearcoat - switching to this method saved me a HUGE amount of time.
JRO [surname deleted for privacy by Editor]
- Winterport, Maine
thumbs up signAwesome advice JRO. I followed your advice and got some great results. Thanks. All I can add for people doing this in the future is to sand as unidirectionally as possible. The more consistent direction the better it looks. And clean aluminum thoroughly with detergent before buffing or it will blacken the buffing wheel. I learned that buffing wheels can be run through the washing machine.
Martin Osvath
- Harrisonburg, Virginia
Q. I have a 2000 CBR F4, I just polished the frame and it looks sick. Thanks for all the advice, but one question: what do I use to keep and maintain the shine? like Painting clearcoat? What are my options for maintaining the shine? Thanks.
Michael Shults
- Burnt Hills, New York
Ed. note: See also
• Thread 800 "Aluminum motorcycle polishing -- rims, wheels, swingarm, frame" and
• Thread 10917 "How to polish aluminum for motorcycles to chrome like finish", folks.
A. Before you attempt to sand and polish an aluminum frame. YOU MUST REMOVE THE FOLLOWING PARTS: GAS TANK, FAIRINGS AND ANY OTHER PARTS THAT YOU DON'T WANT DAMAGED!
STEP 1: YOU WILL NEED TO PURCHASE Aircraft Stripper. THIS TYPE IS NEEDED DUE TO THE TOUGHNESS OF THE ANODIZED COATING ON THE FRAME.
STEP 2: COVER ENGINE AND EXHAUST WITH PLASTIC BAGS OR TARPS AND TAPE OFF TO SEAL THESE COMPONENTS AND ANY OTHER COMPONENTS THAT MAY COME IN CONTACT WITH PAINT REMOVER. THIS STUFF IS VERY STRONG!
STEP 3: BEFORE APPLYING PAINT REMOVER MAKE SURE YOU ARE WORKING IN AN OPEN AND VENTILATED SPACE. HAVE A GARDEN HOSE HANDY FOR TWO REASONS: a) RINSING PAINT REMOVER FROM YOURSELF (THIS SH*T WILL BURN YOUR SKIN!) b) TO RINSE REMOVER OF PAINT REMOVER FROM THE FRAME.
STEP 4: READ DIRECTIONS FOR PAINT REMOVER! APPLY PAINT REMOVER TO PARTS OF FRAME THAT WILL BE EXPOSED (OUTSIDE OF FRAME ONLY). ONCE REMOVER IS APPLIED KEEP A WATCHFUL EYE ON THE REMOVER. THE PAINT REMOVER SHOULD START STRIPPING THE COATING VERY QUICKLY. USE A CLOTH TO WIPE A SMALL SECTION TO CHECK THE PROGRESS OF THE PAINT REMOVER. SOME AREAS MAY REQUIRE MORE TIME THAN OTHER, FOR INSTANCE THE PART OF THE FRAME THAT IS CLOSEST TO THE TANK WILL STRIP FASTER THAN THE AREA WHERE THE WELDS ARE.
STEP 5: ONCE THE ANODIZED COATING HAS BEEN STRIPPED BEGIN TO RINSE THE PAINT REMOVER OFF OF THE FRAME. MAKE SURE YOU RINSE PROPERLY BECAUSE THE PAINT REMOVER WILL CONTINUE TO WORK LONGER.
STEP 6: WASH YOUR STRIPPED AREAS WITH WARM SOAPY WATER AND THEN RINSE AGAIN.
Gasoline-powered Air Compressors
air_compressor
NOW YOU ARE READY TO BEGIN SANDING YOUR FRAME. THERE ARE SEVERAL WAYS TO DO THIS. THE EASIEST WAY IS BY USING A "DIE ANGLE GRINDER" ⇦ this on eBay or Amazon [affil links] (AVAILABLE AT LOWES, HOME DEPOT OR SEARS) AND YOU'LL ALSO NEED AN AIR COMPRESSOR [adv: air compressors on eBay or Amazon [affil links] , FITTINGS AND AN AIR HOSE. A 50 GALLON COMPRESSOR OR BIGGER WILL BE NEEDED. YOU WILL NEED TO BUY 3M SANDING DISCS FOR THE DYE ANGLE GRINDER FROM YOUR AUTO PAINT STORE START WITH A 220 GRIT FOR YOUR FIRST STAGE AND WORK YOUR WAY UP IN GRITS. FOR EXAMPLE: 220 GRIT, 320 GRIT, SKIP TO 600 GRIT, 800 GRIT, 1000 GRIT, 1500 GRIT, AND THEN 2000 GRIT. THESE SHOULD BE AVAILABLE TO THE AUTO PAINT STORE (YOU WILL NOT FIND THEM ANY WHERE ELSE UNLESS YOU GO ON-LINE) NOTE: THESE ARE NOT NOR NEED TO BE WET TYPE SANDING DISCS. AFTER YOU HAVE GONE THROUGH ALL THESES STAGES THEN YOU WILL BUFF THE FRAME WITH "MOTHER WHEEL OR ALUMINUM POLISH' SOLD AT ANY PEP BOYS, DISCOUNT AUTO PARTS, etc. TEST A SMALL AREA GOING THRU ALL THE SANDING STEPS THEN WITH POLISH TO SEE WHAT YOUR END RESULT WILL BE. THE TEST AREA SHOULD HAVE THE APPEARANCE OF A CHROME FINISH. YOU SHOULD NOT HAVE ANY HAIRLINE SCRATCHES IN YOUR FINISHED LOOK. IF YOU DO THEN YOU NEED TO CONTINUE SANDING STARTING WITH THE LOWER GRIT WORKING YOUR WAY UP TO THE HIGHEST GRIT.
IF YOU DON'T WANT TO SPEND THE MONEY $$$$, THEN YOU'LL HAVE TO DO IT BY HAND. DO NOT BE IN A RUSH TO START THIS PROJECT BECAUSE IT WILL TAKE SOME TIME TO GET THE CORRECT RESULTS. BEAUTY HAS IT'S PRICE AND YOU ARE GOING TO PAY ONE WAY OR ANOTHER.
TO DO IT BY HAND YOU WILL NEED THE FOLLOWING:
a) A SANDING BLOCK (IT'S MADE OF RUBBER AND SHOULD HAVE SLITS ON BOTH ENDS TO ATTACH THE sandpaper TO.
b) WET TYPE sandpaper STARTING WITH A 300 OR 400 GRIT, A 600 GRIT, 800 GRIT, 1000 GRIT, 1500 GRIT, 1800 GRIT, THEN 200 GRIT.
(-- NOTE THAT THE 3M SANDING DISCS WILL HAVE DIFFERENT NUMBERED GRITS COMPARED TO HAND WET SANDING GRITS. THE TEXTURE IS ALSO DIFFERENT DO NOT COMPARE THE TWO --)
STEP 7: BEGIN TO SAND YOUR FRAME STARTING WITH THE LOWEST NUMBER GRIT. FOLLOW THE FLOW OF THE FRAME AND KEEP AN EVEN PRESSURE WHILE SANDING. YOU ARE WORKING WITH A WET TYPE sandpaper SO IT MUST BE KEPT WET AT ALL TIMES. KEEP A BUCKET OF WATER AND A SPRAY BOTTLE BY YOUR SIDE WHILE SANDING. DUNK YOUR SANDING BLOCK IN BUCKET TO REMOVE SANDING RESIDUE. ONCE YOU HAVE SANDED THE FRAME WITH THAT PARTICULAR GRIT YOU WILL NOTICE THAT THAT PARTICULAR GRIT IS NO LONGER EFFECTIVE AND NOW YOU MUST MOVE ONTO THE NEXT GRADE OF GRIT. CONTINUE SANDING THRU ALL THE DIFFERENT GRADES OF GRIT UNTIL YOU HAVE ACHIEVED A SMOOTH FINISH. TO CHECK YOUR PROGRESS RUB A SMALL AMOUNT OF "MOTHER'S ALUMINUM WHEEL POLISH" WITH A CLEAN MICRO FIBER TOWEL TO SEE WHERE YOU ARE AND HOW FAR YOU NEED TO GO TO ACHIEVE THAT CHROME LOOK FINISH!
MY FAIR WARNING TO YOU: REMOVE OR COVER ALL PAINTED PARTS THAT YOU DO NOT WANT DAMAGED BY THE PAINT REMOVER OR FROM sandpaper! DO NOT START THIS PROJECT IF YOU PLAN TO RIDE ANY TIME SOON CAUSE YOU WILL BE WITHOUT YOUR BIKE UNTIL YOU FINISH.
GOOD LUCK
Eric Bermudez
mobile polishing & detail - Fort Lauderdale, Florida
Wet sanding aluminum motorcycle
"Metal Fabricator's Handbook"
metal_fabricators_handbook
AbeBooks
Q. I have an aluminum Honda CR250 and I was told to wet sand it with 1000 grit sandpaper [1000 grit on eBay or Amazon [affil links] . However when I did that it scratched the aluminum. I've tried polishing it but the scratches are very evident and quite blotchy. My question is what do I need to do to get the scratches out? Thanks for your input.
Steve Payne
motorcycle repair - Mapleville, Rhode Island, USA
Honda CR250 Accessories on eBay (affil link)
A. Could you tell us what parts you were trying to sand? Why did they need sanding? 1000 grit is typically pretty mild stuff, were you using water to keep it wet?
What did you use to polish it with afterwards? Chemical polishes like Mothers Mag & Aluminum Polish this on eBay or Amazon [affil links] and others will not get rid of scratches. They are meant to remove oxidation and road-film.
Using buffing wheels this on eBay or Amazon [affil links] and brown tripoli buffing compound this on eBay or Amazon [affil links] will remove sanding scratches from plain aluminum. If you have clear coats or anodizing on the parts, that will have to be removed, but I have seen anodizing get removed with aggressive polishing. You will have to polish the entire part to get an even finish. Of course, the protective anodize coat is now gone as well!
Ray Coogan
- Lake Havasu City, Arizona, USA
Q. I am sanding a aluminum motorcycle frame. I am trying to restore it. I've wet sanded it with 400, 600, 1000 grit paper. I've used a buffing wheel on a drill with red jeweler's rouge this on eBay or Amazon [affil links] compound but still have spider scratches that make it appear cloudy. I've polished it and it's shiny but still has many scratches. Can anyone tell me what type of polishing wheel to use and what I should use to take the scratches out. Any advice would be greatly appreciated. Thank you
Steve Payne [returning]
Q. HEY I'M TRYING TO POLISH MY OWN FRAME; I JUST WANT TO KNOW WHAT THEY MEAN: "After that use 320 grit sandpaper and continue to 1500, wet sanding at 1000-1500". DO THEY MEAN USE 320 GRIT AND CONTINUE TO SAND AT 1500 RPMS OR THE GRIT 1500? Please SOMEONE ANSWER THIS FOR ME.
MIKE JONES
RIDER - CHICAGO, Illinois
A. 1500 grit sandpaper, not RPM.
Chuck [surname deleted for privacy by Editor]
- C'ville, Pennsylvania
Q. After you have removed the protective coating and sanded/polished the aluminum piece what should you use to protect the aluminum (Protective coating)?
Norman Macoomb
- Stittville, New York
A. After polishing aluminum to bright shiny finish then use some type of automotive wax finish protection. It can be carnauba wax or synthetic wax. The polished bare aluminum finish was used by American Airlines for years and was even considered lower maintenance than painting but it must be waxed regularly to prevent the dull oxidation build up. In more corrosion prone environments from salt exposure then fresh water rinse often and wax even more often.
Please do not confuse chemical conversion coating ("Alodine" trade name) with "anodize" aluminum finish. Anodize is forced oxidation by electrical current in an acid bath solution (sulfuric, boric/sulfuric blend, chromic or phosphoric acids are commonly used) where the aluminum is the anode as in a form of reverse plating in that the base metal aluminum is changed to aluminum oxide. The thickness and hardness of the aluminum oxide determines the added corrosion resistance and can be color modified by adding stains or pigment from paint like materials.
It is not uncommon to clear top coating like poly urethane over anodize. As seen earlier in this discussion the high quality paint strippers can be used to remove this clear top coating but abrasive wet sanding is by far the best for removing anodize. Pure chemical removal can be done with caustic solutions. Sodium hydroxide or potassium hydroxide commonly found as part of products like Drano or Liquid Plummer. After the heavy aluminum oxide anodize removal then use nitric acid rinse or dip to desmut is best or with light smut use phosphoric acid (Naval jelly) to lighten the aluminum surface for a clean dull bare aluminum finish. This would be recommend for a rough texture surface like as cast finish that would be very difficult to add a uniform mechanical sand or abrasive polish finish.
Don Dees
- Athens, Alabama
September 14, 2009
Q. I have a 2000 GSXR and I started the polish process on my frame. I didn't know to take the protective cover off so I started with a angle grinder, using a stripper pad. it took it down to the aluminum then I proceeded to sand. I started with 240, 320, 600,1000 then 1200, the 2000 looked like it wasn't working so I took back dow to 1200. it had a shine so I began to buff using a drill with buffing wheel, brown, green then white. it shines but has a cloudy look. can someone please tell me what I'm doing wrong, I really want to get this. I feel I'm so close!
Andre jackson
hobbyist - st louis Missouri united states
October 17, 2009
Rough edges on aluminum billiard rack are tough on felt table
Q. I have a delta 13 select billiard rack that is screwed together. There are some rough edges at the seams that I'd rather not have against my pool table felt.
It's anodized aluminum. I had been advised not to mess with it, but the replacement has the same issue.
So what is the best way to eliminate the rough edges -- sanding? What grit?
What is the problem with sanding a seam of anodized aluminum?
fred modesta
consumer - montrose, New York
July 14, 2018
1831-1a (courtesy of Billiards.com)
1831-1b (courtesy of Billiards.com)
A. Hi Fred. According to billiards.com, the Delta-13 Select is a one-piece aluminum diecasting whereas the Delta-13 Elite is screwed together from machined billet aluminum components. I know nothing of billiard racks, and they could be wrong … I'm just trying to understand what you have in order to understand the nature of those 'rough edges', whether they are diecasting sprue, or what.
There is a lot of info on this page about what sanding grits to use. A central point is that you'll need several because you can't get a smooth surface with rough sandpaper, but it would take eternity to sand away rough metal with a really fine abrasive.
After you're done, you'll need to clearcoat the aluminum because you will have removed the anodizing. Good luck.
1831-1c
A. Hi again. That's quite a mismatch and I think you'll have trouble sanding it straight without some experience and specialty jigging. I'd suggest disassembling it and trying to assemble the three pieces in the best order and with the best side up for a better fit … then tightening the bolts while using a clamp to hold the parts in proper alignment.
Henry Ford had some ideas on this problem you're experiencing of needing to pick & choose which ends of which parts to bolt together for a proper fit :-)
