Stainless steel to stainless steel friction coefficient
For a bridge bearing improvement study I need to know the friction coefficient between two stainless steel plates. Plates will approximatelt be 500x500mm size with a thickness about 4mm. Since I need to prove my calculations, the coefficient to be suggested better to be referenced somewhere.
Rustu KOSEOGLU
Structural Engineer M.Sc.
Rustu Koseoglu
bir engineering, structural design - Balgat, Ankara, Turkey
