Assistance with tech. question concerning standard Zinc plate yellow chromate
I need some anwsers about Zinc plate Yellow chromate finish. i.e., GM
4344M 6D96/48.
How many days after the finish is applied, is the part fully cured
Is there a finish hardness diffrence on day one compared to day 14
( after finish is applied) ? Does heat to the finish change or distort the finish ? If so what tempatures, and what does it do to the finish ? Will this tempature to the finish change the salt spray protection of 96/48 ?
How can someone tell if the processor skipped the required bake cycle required for this spec ?
- Chesterfield, Michigan, USA
Yellow chromate on Zinc ( or aluminum) require at lest 24 hours to cure. There may be a small change in the 14 -day period you mention, but not very significanat. Heating above 150 °F will dehydrate the protective film. The result is loss of salt spray protection, and loss of the self healing properties of chromate conversion coatings.
Don Baudrand
(Don is co-author of "Plating on Plastics" [on Amazon or AbeBooks affil links]
and "Plating ABS Plastics" [on Amazon or eBay or AbeBooks affil links])
Standard Process would be to Plate part as you normally would except dry good with out chromate, Bake for hydrogen embrittlement the chromate or brite dip in .5% nitric acid and chromate (of course all the rinse's) depending on process, how well parst are pre-dried and and there may be some dullness to the parts
Chris Snyderplater - Charlotte, North Carolina
