Conditions for proper drying of enamel paint
I need to know at what temperature do I need to dry enamel onto brass plaques? And also how long do they need to be at this temperature? Also after sanding the letters, a clear coat of a two-part hardened acrylic polyurethane is sprayed on and then oven baked. What temperature does this have to be and how long?
Best Regards
SandMold Systems - Newaygo, Michigan
Ballpark figure would be 20 to 30 minutes at 350 °F.
Ronald ZeemanCoil Coating - Brampton, ON, Canada
