Kovar soldering
I need to join nickel plated copper wires to Kovar pins. Should I use one of the nickel bearing solders? Presently, we are using TIG welding with no filler wire and are having some problems with cracks and porosity.
Steven Obenour
aircraft engines - Jacksonville, FL, USA
