A problem in grinding Aluminum
I'm am having a problem in grinding Aluminum.we have specific tolerance. But we are not able to get it within it. We are currently grinding Aluminum in a grinder which as two grinding wheel one is called counter wheel and the other is called cutting wheel with the help of cutting oil.
ANKUR PATAL
job-work - RAJKOT, GUJARAT, INDIA
If you need advice on how to obtain a "specific tolerance", Mr. Patal, please tell us what that tolerance is. What tolerance are you presently getting?
I have a similar problem. the material is ADC6. Any advice on the type of wheel,which bond,which cutting fluid etc.
vikram dogra
Vikram Dogra
Irusha India - Chandigarh, India
