Where to check updated EN1811 nickel release standard?
I have heard from customer that European Union is considering to stricten the EN 1811 nickel release standard from <0.5ug/sq.cm/week to <0.2ug/sq.cm/week. May I know where could I check the news if it is true or not? Thank you very much for answering.
Heidy Sungplating factory - Milano, Italy
You should contact CEN directly to discuss changes to their standard EN 1811. Use the following link for more information: http://www.cenorm.be/cenorm/index.htm
Toby PadfieldAutomotive module supplier - Michigan
