Anodizing Al cast
Is it possible to anodize Al cast if there are steel parts inserted in it (incovered). If not, why?
Atanas Irinchev
- Miami, Florida, USA
If the steel is exposed to the anodizing solution it will be destroyed.
The anodizing process uses a sulfuric acid solution that will dissolve uncovered steel parts. It can be done if the steel parts are thoroughly masked using RTV silicone or other simialar masking agent.
Ray Coogan
- Lake Havasu City, Arizona, USA
