Thread 325/81
Hot vs. cold phosphating -- differences and advantages
Q. I would like to know the difference between hot phosphating and cold phosphating. Basically we are using hot 7 tank process for our pre treatment of steel, both HR and CR before powder coating. I would like to switch over to cold process. Kindly give me the advantages.
Kindly advice
Gangadharan Ruppa- Chennai, Tamil Nadu, India
publicly reply to Gangadharan Ruppa
A. Dear Mr G Ruppa,
Cold phosphating has no advantage over hot phosphating apart from saving your heating costs.
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
publicly reply to Khozem Vahaanwala
A. Dear Mr. Gangadharan Ruppa,
I do agree with Khozem Vahaanwala that cold phosphating offers savings in heating costs. The other advantages of cold phosphating are:
The problems due to overheating of the phosphating bath [Metal Finishing (U.S.A.), 93(1) (1995) 30-31] and difficulty in maintaining heating coils could be avoided with the use of cold phosphating. However, cold phosphating requires more processing time to achieve the desired amount of phosphate coating weight and in a continuous process line the processing time has to be adjusted accordingly.
T.S.N. Sankara Narayanan
- Chennai, Tamilnadu, India
(ed.note: The good doctor offers a fascinating blog, "Advancement in Science" )
publicly reply to T.S.N. Sankara Narayanan
Q. Hello everyone, my situation is that I want to change my Hot Phosphating system to Cold. Please can anyone help me out on this issue.
Adeel Ahmed- DUBAI, UAE
March 25, 2013
publicly reply to Adeel Ahmed
Cold phosphating
Q. Is 3-in-1 solution good for surface preparation. Some manufacturers supply 3-in-1 chemical (Degrease, Derust and phosphate combine) and recommend to use it by dipping as well as by simply wiping on the surface. How authentic is this process? Should we opt for it for painting heavy machinery as 7 tank is not possible and blasting also is not possible.
Ravinder NegiPaint Shop employee - Bhiwadi,Rajasthan, India
October 24, 2017
publicly reply to Ravinder Negi
A. Hi Ravinder. I'm not sure why the 7-tank process is not possible, but dropping from 7 hot stages all the way down to 1 cold stage is a pretty big fall. I think the only favorable thing we can say is that anything is better than nothing :-) Good luck.
October 2017
publicly reply to Ted Mooney
Q. Dear sir
I am new in powder coating industry. So please tell me the details of 3 in 1 chemical. How to use and what are steps to follow.
Raman
Powder coating - Chennai,tamil nadu, India
July 19, 2019
publicly reply to Raman gresan
A. Hi Raman. Traditionally, the 3-step process, or 3 in 1, has meant iron phosphatizing, wherein a single process tanks contains the necessary ingredients (as Ravinder says above) to clean, de-rust, and phosphatize; the second tank is a rinse; the third is a dilute chromic acid passivating solution.
Although it is theoretically possible to formulate your own 3-in-1 processing solution, it's probably far more practical to find a supplier of the process. Because of concern over the toxicity of chromic acid, they will probably suggest a proprietary passivation chemical as well.
by Biestek & Weber
Biestek & Weber is virtually impenetrable as a quick reference, but if you take the time to tune your mind to their wavelength, pp. 212 to 224 are an extremely clear exposition of everything there is to know about iron phosphatizing :-)
You can also search this site with the term "3 in 1". Good luck.
July 2019
