Substitute for MEK for solvent cure test
Q. Does anybody know a substitute for MEK / methyl ethyl ketone ?
The MEK is used for solvent cure test on powder coating according to Powder Coating Institute (PCI) Recommended Procedure #8 (solvent Cure Test).
I heard that this solvent (MEK) produces cancer. Does somebody knows a substitute for the MEK or other Solvent Cure Test for powder Coatings that does not use MEK?
Armando Romero
- Guadalupe, Nuevo Leon, Mexico
A. Dear Sirs,
In some instances MEK is too severe for the solvent rub test and MEK is then mixed with a diluent such as Toluol at 1/9 MEK/Toluene.
Other specifiers state that MIBK (methyl iso butyl ketone) for the evaluation of the cured coating.
The choice of which type of solvent/blend is down to the customer that is looking for some degree of satisfaction that the coated items he receives is fully cured. He may having previously carried out evaluation trials to arrive at the type of solvent and the number of rubs required to satisfy him that the powder has been baked to his requirements and this may differ company to company.
Terry Hickling
Birmingham, United Kingdom
Xylene
xylene
A. Hi Armando,
First of all MEK does not produce cancer (check in Material Safety Data Sheets). But if You don't want to use MEK you should try to use Xylene this on eBay or Amazon [affil links] . Xylene is recommended to Solvent Cure Test for Powder Coating by Qualicoat. More info you will find in Qualicoat specifications page no 15. You can download it from: http://www.qualicoat.net/uk/download/i-uk-download-index.html
Adam Blaszke
Powder Coatings - Gdansk, Poland
A. Hi Armando,
MEK is also prohibited in California. We use acetone this on eBay or Amazon [affil links] Warning! highly Flammable! for the cure test. It works just as good as MEK test.
Bao Nguyen
- Livemore, California, USA
April 28, 2012
A. Use acetone this on eBay or Amazon [affil links] Warning! highly Flammable! .
Dhananjay Gadkari
- Pune, Maharashtra, India
February 8, 2015
