Prevent rusting more effectively at coastal areas
I would like to know what can be added to a paint to prevent Rusting at coastal areas. As coastal environment damages the paint as we are facing this problem in paint we are using.
Rahul Kaushal
JVR Forgings Limited - Ludhiana, Punjab, India
Coatings are coordinated systems designed to fight corrosion; you don't just add a miracle ingredient, Rahul. What is the substrate, the mechanical pretreatment, the phosphatizing process, and the class of paint you are using?
