Niflor coating
My B.S. project is inquiring about niflor coating(one of the metalurgy and tribology subjects)at industrial working. Would you please give me some fundemental information about applying NIFLOR COATING theorically and niflor's comonents as a composite material more than has published in letter "31055"? more thanks.
Alex Hoshyar
fara koosh - Los Angeles, California, USA
See letter 263.
Applying Niflor ...?
Respecting to fairly low hardness of this nickel-electroless coating (250-400 V.H.N.)in spite of journals that introduce it as an extremely hard composite , Is niflor suitable for coating the gears under load e.g. in gearboxes ? I know it used in mold cors , pomp rotors , standard nut & bolts and some other precision applications. (without loading!)
Alex Hoshyar
farakoosh - L.A., California, USA
