Tin plating slivers during stamping
Q. We have a stamping job that requires forming .0325" thick copper alloy with tin pre-plated material. We have run into problems with plating being scraped into slivers. Are there plating bath additives or processes that will prevent this? We have had many successful runs, but recently significant problems.
Brian ShoemakerStamping facility - Butler, Pennsylvania, USA
A. Tin, even bright tin, is quite soft and lubricious; that is why it is used (often in conjunction with lead) as a bearing material. However, when pinched, it can sometimes gall. I wonder if your problem is that the copper sheet is slightly too thick for your punching tools and there is insufficient clearance for the sheet to fit in the closed die.
A. If it is a forming issue, the mating surfaces may have developed imperfections causing the scoring. Check them out with a strong magnifying glass. If it is a plating issue, the coating thickness may be out of tolerance. Depending on how tight the tolerances are, you can adjust the thickness accordingly. It's also possible the plating bath is co-depositing impurities that are interfering with the forming process.
Jim Conner
Anoplex Software
Mabank, Texas USA
Q. We have the same problem. Stamped material has slivers, and even though we check twice, our customer detects slivers during assembly.
Sorin- Timisoara, Timis, Romania
January 18, 2013
A. Hi Sorin.
Just to be clear, you are still talking about tin plated copper, and it is the plating that is producing slivers, not a lack of sharpness/fit of the dies?
January 18, 2013
