Alternative coating to zinc (cost effective)
I wish to prevent a steel component from rust (storage not external use) and have tried zinc plating (yellow and bright). I have 2 problems, first there seems to be a reaction with a phosphate bonded potting compound which coats part of the steel tube. Secondly I am thinking about welding a part to the tube but am concerned about toxic fumes.
Because zinc seems unsuitable I have tried a black coating which I was told was carbon black, although I suspect is some kind of etching in a hot bath. Do you have any suggestions for a solution, or the best solution for a protective coating suitable for welding and use with phosphate bonded cements?
MANY THANKS
Xylene
xylene
James Yardy
thermocouples for molten metal - Sheffield, Yorkshire, UK
To prevent metal from corrosion at cheaper costs, you might be able to get asphalt, asphaltene I believe is one of corrosion coating product, but how to dilute the asphalt to become liquidize, you can try with tce, but cheaper if use Xylene this on eBay or Amazon [affil links] , until you find a viz level you wish. Okay, good luck
Daniel Herman S Suhendra,drs
dp minchem int - Jakarta, Indonesia
You might try E-coat. Depending on how long your tubes are you can get really good coverage. With the immersion tanks you can get about 15 inches throwpower from each hole. Its a thought right?
Curt James
- Arlington, Washington, USA
You can use 2o gm tannic acid this on eBay or Amazon [affil links] /15 gm phosphoric acid /1 lit water solution,after this process you must lacquer, cheap paint is 2oo gm shellac/1 lit pure alcohol, mix it with iron oxide black pigment.
