  Thread 323/73
Materials that can be coated with Teflon?
Greetings !
I wonder if it is application of Teflon coating or any other non-stick coating limited to only metal or is possible to coat any other material !? Stone, marble, concrete,...?
Could someone describe coating process little bit more precisely?!
Can I do it on my own at home ?
With best regards!
Uros Ocepek
hobbyist - Novo mesto, Slovenia
publicly reply to Uros Ocepek
Yes you can coat all tha surfaces that resist the curing themperature (about 380°C). There are also low bake temperature teflon coatings.
You can learns more about the teflon coating process at www.fisasa.com/teflon_proceso.htm
Best regards,
Jordi Pujol
- Barcelona, Spain
publicly reply to Jordi Pujol
