8th-grade Dissolving Teeth Project
I'm doing my science fair project on which liquid dissolves your teeth the most.
I have already started my project with my teachers approval but now I need to look up notes on my project so that I'm staying with the rest of my class who have not started yet.
Do you know the pH levels for:(1)water (2)lemonade (3)Sprite and (4)Hcl or hydrochloric acid
*(my teacher disstilled but the extent of how much it was disstilled I do not know)*
Also if you had any notes on dissolving teeth in any of these liquids would also be helpful.
Alex S.
8th grade science fair - Austin, Texas
Alex,
This seems like a great experiment. You most defiantly are going down the right path with finding the properties of each solution. Another thing you can look into is what teeth are made of. I am sure a dentist would love to answer that question. As for the pH of the solutions you should ask you school if they have a meter or some other means to test for the pH..
Good luck and have fun.
Kevin Dodd
- Austin, Texas
HiYa!
pH level scale runs from strong acid ph-1 through strong alkali pH 14. Water is technically neutral at pH-7.
(2) lemonade is citric in acid and depending on concentration can range pH 5.5 - 6.0.
(3) Sprite is a light acid pH 5.00 - 6.00
(4) HCl or Hydrochloric Acid is an extreme acid and depending on concentration falls between pH 1.00 - 3.00. PLEASE AVOID CONTACT WITH SKIN OR INHALATION OF VAPORS, it is quite armful.
You may want to substitute regular house vinegar in bulk on eBay or Amazon [affil links] would do to teeth. Now a quiz: What property do bone and teeth have in common?(What are bone and teeth made of?)
Fun with chemistry and enjoy!
=CHRIS=
Chris Friedberg
- Newington, Virginia
You can buy some litmus paper and test the pH level of the liquids.
Karen Sauler
- Atlanta, GA, USA
Sorry Karen but litmus paper will only tell you if it is above or below a specific pH for red and for blue litmus paper. A narrow range pH paper in several ranges below 7 will give decent results. For good results you will need a pH meter.
