Cleaning buffing compounds off aluminum
I NEED TO KNOW A GOOD WAY TO CLEAN BUFFING COMPOUND OFF ALUMINUM [BILLET] WE ARE HAVING TROUBLE GETTING OUR PLATING TO HOLD ON THE CORNERS. WE ARE GETTING WHAT I CALL BLISTERS WHERE THE PLATING IS NOT STICKING ON THE CORNERS.
Mike Jenkinsfinishing shop - Anthony, Kansas, USA
Dear Mike,
Yes...you can not plate without removing buffing compound. You can try a solvent, n-bromo propane, either dip or spray. But use proper goggles ⇦ this on eBay or Amazon [affil links] / rubber gloves ⇦ this on eBay or Amazon [affil links] etc. You can also try out with Henkel-Loctite range of products ( please contact local dealers)
Good Luck
Keshava Prasad M- Bangalore
This is a rather general answer, Mike, but I think the best approach is probably to add ultrasonic cleaning to the process.
Ted is right, an US cleaner is perfect but... also expensive.
There are quite a lot of chemical cleaners that can do the job even without US. Most of them operate at high temp, like 60-80 °C and almost neutral pH. Ask your supplier for a buffing removing compound. I am sure he will come up with an adequate product.
Sara Michaeli
Tel-Aviv-Yafo, Israel
Similar things happened here. After buffing the aluminum, there's residue of compound sticking there, but our company managed to clean with a product called Cosmoline. I believe that's available in many places already, but you can compound that by yourself, utilizing Xylene ⇦ this on eBay or Amazon [affil links] / pce/ and butyl cellosolve.
Well good luck,
Daniel Herman S Suhendra,dwi putri minchem int - Jakarta, Dki, Indonesia
