Yellow Stains On Nickel Plated Strips
I have some plating problems in surfacing nickel on High Carbon Steel Strips (5.5x0.30mm)
Somtimes we encounter yellowish stains or yellow deposits on the surface after drying in a centrifugal drier. 98% of production comes very clean, but the remaining 2% needs to be rewashed and only then the yellow stains are gone. This process hampers our production severely.
Please can you guide me to a solution as to what or where we may be going wrong?
Nauzad Mun
- Mumbai, MAH, INDIA
Use better rinsing before the dryer and consider a lower temp (longer drying period is a negative result) drying.
Add antipit at 2 ml/ltr. liquid in the last rinse prior to drying.
N.K.Praveen Kumar
- Secunderabad, India
adv. saify ind youtube
