RoHS -- is the chromium in 6061 / 5052 aluminum hexavalent?
Q. For the purposes of the New EU Directives and RoHS compliance, a maximum concentration value of up to 0.1% by weight in homogenous materials for hexavalent chromium will be permitted in the manufacture of new EEE.
Is the Chromium (Cr) found in 6061-T651, 5052-H34 or other common Al alloys hexavalent form? (please refer to http://www.aerospacemetals.com/aluminum-distributor.html for aluminum specs)
Costa ChristopoulosRoHS & WEEE - Montreal, Quebec, Canada
A. No, the Cr is not present in the hexavalent ion form when it is alloyed with Al, steel, etc.
Toby PadfieldAutomotive module supplier - Michigan
Q. Good morning Costa. Did you finally find an answer on your question about chromium hexavalent. We are aluminium producers in Greece and I'm also interested on that topic. Can you please share some information with me?
Best regards,
- Paralia Distomou
August 29, 2023
Q. Currently we are specifying MIL-A-8625 [⇦ this spec on DLA] Type II for an anodize finish on 5052-H32 and 6061-T6 aluminum components in order to meet RoHS compliance requirement. A question comes up whether 5052 or 6061 themselves are RoHS compliant because of the amount of chromium in the base alloy material. I understand that there are 3 types of chromiums - zero valent, trivalent and hexavalent. Can anyone tell me what type of chromium is inside 5052 and 6061 alloys and if they are RoHS compliant? Thank you very much.
Jacky Yam- Hazelwood, Missouri, USA
July 3, 2014
A. Hi Jacky,
Although when chromium is ionized in solutions and in salts (including chromate gels) it may be in the trivalent or hexavalent state (possibly even the divalent state), actual metals like chromium are in the metallic state, oxidation state 0. And in the general case like atmospheric corrosion, chromium metal will oxidize into trivalent form.
