Cost difference between zinc plating and hex chromate
Which is a less expensive process - zinc plating or using hex chromate?
KENNETH MERHAR
MSU - WARREN, MICHIGAN, USA
Are you sure you understand the question, Kenneth? Normally one would zinc plate and then apply either a hex chromate or a trivalent chromate conversion coating.
