Brass cleaner for cartridge cases?
I'm looking for a better and faster method of removing outside tarnish and burnt powder from the inside of my cartridge cases (brass).
Gene Baskin
hobbyist - Rowlett, Texas, United States
Better and faster than what current method, Gene? There are case cleaners starting from simple chemicals and going on all the way to tumbling barrels and abrasive media.
I have tried all of the products mentioned in your reply, but I'm not satisfied with the results. Several years ago I purchased some once fired military brass from a local source. This man told me he used a solution with a mild detergent to achieve the results I am trying to duplicate. Unfortunately this man died several years ago and his family moved.
Gene Baskin
- Rowlett, Texas
acetone this on eBay or Amazon [affil links] Warning! highly Flammable! seems to work reasonably well. I have used Q-tips this on eBay or Amazon [affil links] soaked with it and swabbed it onto the cartridge case. It removes most of the crud...not all, but it's a start. Hope this helps!
Jill Errickson
- Miami, Florida, USA
Try this link: http://www.geocities.com/CapitolHill/Lobby/1221/casecln.htm I have used a similar recipe that works well.
Kirk
- CO, USA
