Hast-X vs Hast C276
What are the difference between Hastelloy X and Hastelloy C-276?
Jason Farris
Advanced Precision - Halifax, Nova Scotia, Canada
Haynes International, the producer of Hastelloy alloys, has a great deal of technical information available on their website.
Toby Padfield
Automotive module supplier - Michigan
HASTELLOY X Alloy is used primarily for high temp applications such as hot gas sections of turbine engines and HASTELLOY C-276 Alloy is designed for corrosion resistance and widely used in the chemical processing industry. I suggest you contact Haynes International's Engineering and Technology Department and discuss your specific application with a metallurgist.
Jeff Russo
- Kokomo, IN, USA
