Remove blue from GE 1960 blue stainless steel kitchen wall
I recently purchased a old house that has a GE one piece 1960 blue stainless steel kitchen cabinets that covers the whole wall. Can they be strip of the discoloed blue to stainless steel?
Eric Johnson
Wholesale Bank - Seattle, Washington, USA
You can use 5% water solution of ammonium citrate(pH must be 3,5/you must add some ammonia this on eBay or Amazon [affil links] to 5o gm citric acid this on eBay or Amazon [affil links] dissolved in 1 lit water),if you think that is complicated you can use only citric acid (5% solution in water)!
- Zagreb ,Croatia
