Plating S.S. without a Woods Nickel Strike
     Plating onto stainless steel is a problem because it instantly forms an oxide on its surface whereas, for proper adhesion, plating must be applied directly on metal rather than an oxidized surface. The most common resolution to the problem is to start with a Wood's Nickel Strike ⇦ huh?
Q. What I was wondering, is there a way to plate stainless steel without a woods nickel strike. I have heard that someone is doing this process without the woods nickel strike and was just curious to know if anyone has heard of this or is it even possible?
Brian Gaylets
- Scranton, Pennsylvania, U.S.A.
A. Sulfamate nickel strike has been used with some success on certain types of SS (250 g/L Ni sulfamate, 20 g/L sulfamic acid, 30 g/L boric acid, 10 g/L Hydrochloric acid, room temp, 10-50 Amps/sq. foot, pH-1, 1-2 minutes). The higher grades (300 series or higher) are very difficult to plate if not struck with an all chloride bath such as the Woods formulation. An interesting exception (for localized plating only) would be the acid nickel formulations used for brush plating. They contain no chlorides and are very effective for activating SS.
Guillermo Marrufo
Monterrey, NL, Mexico
A. How about vacuum coating? Either PVD or CVD, with the correct vacuum cleaning technology will work.
A. We plate SST with sulfamate Nickel all the time. We do not use a strike at all. We clean activate and plate.
Guy P.Boucher
- Wells Maine
Q. Guy, how do you clean and activate your stainless steel to obtain good adhesion? Can you give details please, because I have never had any reproducible success with conventional systems.
A. We routinely coat SS base metals by means of Physical Vapor Deposition (PVD). Anything from pure metals such as chrome, to compounds such as TiN or CrN, so it's a realistic alternative for your parts.
Joe Kubinski
PVD equipment supplier - Woonsocket, Rhode Island, USA
? I have worked for two companies that were certified for Pratt & Whitney plating. I have been out of PWA plating for a while, but PWA required a strike for all SS when I was active. Are you in conformance with PWA SPOP's? Also, you do not say what your adhesion test is and do you consistently pass it.
A. I do a lot of stainless steel auto trim. It is usually kind of crappy so I sand it with 80 grit on a D.A. Then up to 120 and finish with 220.
Scrub well in a 1/4:1 sulfuric/water bath and then into my nickel strike bath. (High sulphate nickel strike) Or, if you have cyanide it will do the job.
After a 10 min strike in the nickel strike, rinse and into the copper for a hour.
The rest is just sand, buff, clean, nickel, chrome.
Tom H [last name deleted for privacy by Editor]
- Peoria, Arizona, USA
A. Depends on which alloy you're talking about, but many can be plated with nickel following one to three minute activation in 50% HCl. Rinse and transfer quickly to nickel bath.
? Jeffrey-
What alloy and will a non-struck part pass a bend test?
A. HCl activation will work on the 4XX series as well as the PH grades, 17-4, etc. Yes it will pass bend and all other conventional adhesion tests. It's iffy on the 3XX series. For reasons I don't understand, the HCl has to be fairly fresh. Old HCl doesn't work.
Q. This thread has struck a real chord with me, so please excuse me in advance for being longwinded.
I've been trying to develop a process to plate nickel and then gold over small (in the neighborhood of .4 sq inches surface area per piece), intricately shaped components for over a year now. I'm using a barrel plating process which likely increases the challenge, but I've tried 3 or 4 different processes in 30 or so configurations, and I've yet to find one that passes a crush test to the required standards.
The basis material is 303 stainless steel, and on my most successful trials I get 2-3% adhesion failure in crevices and at edges. Failures usually occur in the areas of highest stress after crush, which should really come as no surprise. I know that it is possible to do better, because we've had a vendor plate the same components, and they've passed the test every time.
The first process I looked at was an HCl activate followed by a Wood's Ni strike. As mentioned above, I've seen that after 2 or 3 uses, the steel no longer gases and the HCl must be replaced. But even with fresh, undiluted HCl, I see failures. I've tried running reverse current through the parts while in the HCl, and that failed as well.
I next explored a reverse current activate in 60% sulfuric, followed by a strike in a sulfuric/low conc NiCl bath. Failures there as well.
Most recently, I've looked into an extremely low conc. copper strike mentioned in a gold plating text. I used the same sulfuric activate as above followed by a strike in an HCl / .3 g/l Cu sulphate-pentahydrate bath. I actually managed to get 100% adhesion on my first trial here, but visually the parts finished very ugly, and follow-up trials soon began to exhibit adhesion failures.
Before beginning the activate, I clean the steel in a hot alkaline soak cleaner. After activate the parts get 50-100 micro-inches of nickel in a brightener free nickel sulfamate bath (pH 4.0), and then 50-100 micro-inches of gold in an acid PGC bath. In all cases I try to minimize the time between activate and strike, and if the acid is the same between the two I do not rinse at all. I've also tried going into the Ni plate bath at extreme current density and then slowly dropping it back to my operating current density. (8ASF) I've tried lot sizes as small as 1/10 of a square foot, and as large as half a square foot and have seen no appreciable difference.
Can anybody see what I'm doing wrong? Recommend a process that I haven't tried or a change to a process I have? I'm beginning to wonder if our vendor isn't using some sort of voodoo magic.
Thanks for the help,
-Ray
Raymond Brown
- New Hanover, Pennsylvania, USA
A. Ray, Based on all of the stuff that you have tried, I do not think that you are getting your parts clean in your soak cleaner. Get with your vendor and try an electrocleaner.
Second, It sounds like the part has cups. If so, it requires better rinsing between the caustic and the acid etch. Third, have the parts been heat treated in any form in an air oven? If so, try an cleaning cycle before going to the oven. You might be baking "stuff" onto the metal, making it difficult to clean. Fourth, have these parts been buffed? If so they will require a cleaning cycle specific to the buffing material. 50% HCl should have little problem activating 303 SS.
I would use a generic Woods Strike that is high in acid and low in nickel. Just seems to work better and puts on a very thin coating, so less stress in that coat. I like about 80 ASF.
Go into the nickel sulfamate "hot" at about half the final voltage. come up to full voltage (amperage) in about a minute. You should not have any problems.
"Electrodeposition: The Materials Science of Coatings & Substrates"
by Jack Dini
diniE
A. Hi. Dini's delightfully quirky "Electrodeposition"
has an 'Adhesion' chapter with quite a bit of detailed data on adhesion strengths of Wood's Nickel Strikes applied under slightly different conditions. Like other plating processes, just because we're doing it doesn't mean we're doing it optimally; some small variations can be the difference between fairly good adhesion and startling adhesion.
A. Brian
In Pratt North Berwick. We run to (POP's) Process Operation Procedures. Our POP 140 allows us to Nickel plate SST. Depending on which alloy it is we REF. AMS2403-ams2424.
1. Electrolytically clean using Alkali solution. Tank temp. 130 °F ±10. Cycle Time: 4 ±1 Minutes. At 25-65 Amps/Sq. Foot. Have current anodic at end of your 10 sec. periodic reverse cycle. Rinse parts in clean DI water.
2. Immerse parts in a 50% Hydrochloric acid solution at room temperature for 45-60 seconds after gassing starts for 30-60 seconds.
3. Pressure Rinse parts thoroughly to loosen smut in DI water.
4. Transfer quickly and immerse to the nickel bath.
Guy Boucher
aerospace - North Berwick, Maine, USA
Q. Thanks for the reply, James. You've mentioned some interesting things.
Our parts are not baked in any fashion, and do not see a buffing process, but I will certainly explore more extensive pre-cleaning.
Is the deposit put down by a Wood's Ni strike highly stressed? It seems that adhesion on all of our substrates is highly sensitive to stressed nickel deposits. I see major failures even on copper substrates when I add just a small amounts of brightener to the nickel bath. My deposit is not that thick (75 microinches or so), so I've never really been able to explain that phenomenon.
Is the temperature of the Wood's nickel a factor? I've never tried heating the bath, even though most production nickel baths run warm to hot...
I'll do some more experiments over the next day or two and see what kind of results I get.
Thanks again,
Raymond Brown
A. A Woods nickel strike has a very high internal stress. That is one reason to only put enough on to get a uniform coating. At one shop we used 300 amp minutes per Sq Ft. Room temp is the proper temp, 70 °F±.
The anode material needs to be rolled depolarized. Electrolytic nickel would be OK, but not SD or RD rounds / crowns / pellets.
A. Like someone had mentioned above, try an electrocleaner on your parts. I am not familiar at all with gold plating, but for what we do we run our soak cleaner at 180 °F, with a 10% makeup. Also another good point is when we make up our cathodic acid (I forget the percentages) we beef it up with 25# of ammonium bi-sulphate (something new we are trying); we have found that this is working great for us in plating Ni over stainless steel!
Brian C. Gaylets
Q. We are currently investigating different methods to activate 303 Stainless Steel. On this thread you indicated you use the Ammonium bio-sulfide method. For the 25 lb makeup, how many gallons is your tank, temp, how many ASF or volts and how many minutes? What is the cathodic acid chemistry and if you have makeup? You indicate that you add the ammonium bio-sulfide with the cathodic acid? ⇐ answer?
Mark Williams
Foresight Finishing LLC
- Tempe, Arizona
Foresight Finishing
April 23, 2018
Wood's Nickel Strike isn't giving good adhesion
Q. Hey guys, can anyone give me a quick conversion from metallic nickel content to NiCl2(H20)6?
Having extreme difficulty with my Wood's bath all of the time, just now got murexide [affil link] in to titrate and determine what is actually happening.
Using procedures from the Metal Finishing Guidebook, titrated the Woods tank 2 mL sample, 100 mL DI H2O, 20 mL conc. NH4OH, bit of murexide [affil link] in NaCl. 0.1M EDTA. Measured 17.2 mL to a fairly abrupt orange to purple color change, by my calculations gives me roughly 6.75 oz/ gal Nickel metal.
Then setup for acid titration, 10 mL sample, 100 mL DI H20, bit of methyl orange ⇦ on eBay or Amazon [affil link] , Titrated with 1.0 M NaOH [1N NaOH on Amazon [affil link] ever so slowly to keep the Ni from precipitating to a sickly green endpoint. Measured 15.2 ml. Now should I titrate for Chloride content as well? I feel like I am missing something simple, any recommendations would be quite welcome, or any additional information needed. It may be just me but the solution appears to be slightly thick, not viscous, but it behaves more slowly than water if that makes any sense.
I have drained the tank, and cleaned it, of course several small parts my operators had no idea how they could have gotten there but I am at a loss. I often have a skip plate, or just an awful black loosely adherent film. This tank is used primarily for barrel operations. Again, I am sure there are several issues but I would like to begin knocking down those that I can. Thanks in advance for any help.
Jordan Egnatoff
- Huntington, West Virginia, USA
November 1, 2018
A. Hi Jordan. That Metal Finishing Guidebook of yours has an appendix labeled "Metal Contents of Common Plating Salts", which says NiCl2·6H2O is 24.7% nickel.
If you want to check their math, another appendix in that volume is "Atomic Weights of the Elements". Nickel/NiCl2·6H2O would work out to:
58.69/(58.69+(35.46)*2+6*((1.008*2)+ 16)))
Fallen parts dissolving into a nickel solution are always a bit of a problem, but sound like a real game changer for the very acidic, low metal content Wood's Nickel Strike. Although dropped parts have often been accepted in high volume plating, I don't think you'll have robust success until you institute a reliable program of removing fallen articles immediately and tracking each dropped part until the problem gets solved. Times are changing anyway whereby old habits like allowing parts to fall into the tank unnoticed are becoming impermissible. Good luck.
nickel book
The Sulfamate Nickel How-To Guide
by David Crotty, PhD & Robert Probert
A. The common reason for a nickel chloride strike ceasing to give adhesion is that the nickel metal content has climbed too high and converted the inefficient "strike" into an efficient "plating solution" which will not adhere. (Pages 3 & 4 in our new sulfamate book)
Use inactive anodes like Rolled Depolarized bars. Take out when not in use. It is near impossible to maintain a nickel chloride strike with very active S-rounds.
robert probert
probertbanner
November 2, 2018
thumbs up sign Ted and Robert,
Thank you both for your insightful and quick responses.
Ted, if I am understanding correctly the 6.73 oz/gal Ni metal content I measured through titration should convert to a Nickel Chloride Hexahydrate concentration of 27.24 oz/gal? Assuming I have done that correctly my concentration of HCl (36%) was 16.94 fl oz/gal which from what I have read is low if I am attempting to keep a 1:1 ratio of the two components.
As for the fallen components, I wholeheartedly agree and have gone through great lengths to educate the operators about it, however, I was only trying to provide as much info about the tank as possible as I have often read that that is the first step in troubleshooting a Woods baths from this site. If at all possible would you or any other reader be able to confirm my figures and offer a possible course of action before I go adding an extra 10 fl oz/gal HCl to the tank? Also, I am concerned about metallic contamination from the aforementioned parts and would be grateful if anyone could suggest whether or not dummying the tank might offer some relief and if so what current density may be the best move. I am interested in saving this tank as opposed to making a new one if possible. Thank any and all in advance as usual, I patiently await your feedback.
-Jordan
Jordan Egnatoff [returning]
November 5, 2018
A. Hi again, Jordan. If your titration is correct at 6.73 oz/gal Ni metal, then your calculation of 27.24 oz/gal is close. People quote somewhat different concentrations for Wood's Nickel, and my old friend Don Wood is, alas, long deceased and can't act as arbiter :-(
Robert frequently uses the easy-to-remember 2 lbs./gal nickel chloride plus 1 quart per gallon HCl. I believe he is referring to weighing the NiCl2·5H20 and measuring 36% HCl by volume, but hopefully he'll confirm.
So your nickel is not too high at this point (if your titration is right) but your acid is low. Adding 10 fl oz./ gal would bring it to (10+16.94)/(10+128) = 25 fl oz. gal (36%), which would certainly not be too much.
Hopefully another reader will know how to remove iron from a Wood's Nickel Strike, but I personally don't, and I believe other posters that using inert anodes can be dangerous (chlorine gas), that dummying with nickel anodes won't work well and, with all things considered, dumping to eliminate the iron might still be the most practical thing to do. When the production department appreciates that parts falling into the strike tank and left there to dissolve condemns you to a shutdown for dumping and makeup, hopefully corrective action will come.
Luck and Regards,
Q. Ted, thank you again for your invaluable guidance, just for kicks, if I were to dummy with rolled anodes to remove other metallic contaminants, such as copper for instance, is there a current density you or another poster might suggest? Or perhaps a chapter or reference in the guidebook which could point me in the right direction? I apologize for the continuing questions, thank you so very much for your input.
Jordan
November 6, 2018
A. Hi Jordan. My knowledge of Wood's Nickel is largely book knowledge and, sorry I have hands-on info to share about dummying of a Wood's Nickel bath.
thumbs up sign No worries, I went about 3 A/ft^2 did manage to pull out a bit of copper, mostly in LCD areas of my plate, adjusted for HCl accordingly find out today whether or not there will be a noticeable difference. Thank you again for the wonderful help.
A. Hi Jordan,
We've dummied copper out of a wood's nickel strike down around 5 ASF but honestly it's way more efficient to just make up a new one. I'd recommend some kind of corrugated sheet because the copper immersion plate loves LCD areas. Without live entry the copper tolerance is really low so dummying only buys a little time. Not sure what your substrate is but find ways to reduce the copper introduction and don't be afraid to dump and recharge.
Jameson Grout
- Springfield, Massachusetts USA
A. Jordan,
The nickel chloride in wood's strike conversion formula:
Nickel chloride = Nickel metal in wood strike x 4.0486
popat patel
Popatbhai B. Patel
