Evaporator descaling
Sir,
I am the Managing Director of the above said company and I was with this evaporators field for the last 10 years.
Even though I was dealing with evaporators , I found struggling when descaling the evaporators, my evaporator is on mild steel shell side construction and my tubes is of S.S.304 . I got scales of sulphate origin with 2 to 3 mm thickness inside the tubes.
What type of descaling chemical can I use? my plant is of glauber salt recovery plant from dyes waste water.
With regards,
Santhosam Ramalingam
handling evaporators - Coimbatore, Tamilnadu, India
You may use one of the following de-scaling chemicals specifically developed for the evaporators
Firms name Product name
GYRO Vaptreat "L"
UNITOR Vaptreat
DREW Ameroyal/Ameroyal CF
NALFLEET Maxi-vap
UNISERV Liquivap/Liquivap CF
Rajesh
Rajesh Kumar
- Delhi
