Deburring material for pen clips
DEAR SIR,
WE ARE MFG. OF PEN CLIPS. I WANT TO KNOW WHATS MATERIAL USING IN DEBURRING. NOW I AM USING EMERY this on eBay or Amazon [affil links] AND CAUSTIC .
Please ADVICE ME
THANKING YOU
Sushil Bohra
DEBURRING OF METAL CLIPS - MALAD (w), MUMBAI, MAHARASHTRA, INDIA
What is the material? Brass? If so, you might need a one or 2 step operation in a mass finishing system. Are parts going to be plated? Need to know before I can recommend properly.
tony kenton
AF Kenton
I ASSUME YOU ARE referring TO HARDENED PEN CLIPS IF ITS CORRECT FIRST STEP SHOULD BE DESCALING AND SMOOTHING USING CERAMIC IN VIBRATORY MACHINE AND SECOND STEP POLISHING IN SAME MACHINE WITH PORCELAIN MEDIA AND POLISHING CHEMICAL TO GET PRE PLATE FINISH.
Prasad
- Mumbai, India
