Copper plating of leaves not quite good enough
I am trying to copper plate leaves not only for a hobby but also as a source of income. I am using an electrolyte of CuSO4-5H2O + H2SO4 + deionized water, a constant current power supply and I have covered the leaves with a lack containing graphite ( the resistance is quite high when dry) and as an anode I have tried copper wire and various other sources of copper. The results have been a powdery bright copper plating taking 12 hrs. with a current of ~0.1A. My question is .. How to get a solid shiny copper plated finish and is there a spray or paint ready for use that would give me better results?
Supplies are very hard to find in this country and are very expensive when available.
Robert Frankel
Hobbyist - Tel-Mond, Israel
Dear Robert!
Ref book -using a parafine/wax/ print to do plating and mixing graphite with water or vodka. For insects should be treated in mercury chloride 1.5%(HgCL2)-dry-lacquer-graphite-plating.
Good luck
Cair Shishani
Khair Shishani
