Want PVD tarnish-free brass coatings
We are exporters of Brass Fittings / tapware and accessories.
Where I can find more information about the process and chemicals for Tarnish - Free Coating which is done in Vacuum.
I am not talking about Lacquers !
I hope you understand and reply back Soon !
Best Regards
Mohit Arora
brass industries - Jalandhar, Punjab, India
A. The process you are looking for is physical vapor deposition (PVD). The most common material deposited is zirconium nitride, with additions of carbon to provide darker hues. This is a rather complex, costly process. First, the polished parts must be thoroughly cleaned, then 12 too 15 microns of electroless nickel is deposited, followed by a thin layer of electrodeposited hexavalent chromium (around 0.25 microns), then the PVD layer is added, also thin, on the order of 0.3 to 0.5 microns. The PVD deposition equipment is very expensive. Key companies in the field include BodyCote (coating services), Hauzer (coating equipment), and Vapor Technologies (both equipment and services, owned by Masco, maker of Delta faucets and Baldwin locks).
jim treglio portrait
PVD Consultant & Wine Lover
San Diego, California
A. As mentioned in previous response, barrier coating by electroplating plus finishing with TiN or ZrN by PVD is the way to go.
Kuppu Swamy
- Chennai, India
adv. saify ind youtube
