Coating ceramic rod with nickel
What is the best way to put a thin nickel coating on to a ceramic rod? Want a conductive coating that will change resistance with temperature.
Burton Northam
data system applications/design - Hampton, Virginia
PVD is probably the cleanest and most ovbious. But in any event you should consider that adhesion will be limited and difference in thermal expansion of both materials is very high so there is a possibility of bond failure at temperture extremes.
Guillermo Marrufo
Monterrey, NL, Mexico
