Want colors or stains on stainless steel ring mesh
Q. A FEW YEARS AGO WE BOUGHT A SOLUTION TO USE ON PLATED STEEL THAT WENT THROUGH A RANGE OF COLORS THAT WENT FROM A BLUE COLOR THRU PURPLE AND BURGANDY DEPENDING ON THE TEMP OF THE WATER AND SOLUTION AND ALSO THE TANK AGGITATION.I THINK IT WAS CALLED BLACK MAGIC AND WAS PURCHED FROM RIO GRANDE.WE ARE LOOKING FOR ANY METHOD TO PLACE COLOR ON STAITLESS STEEL OR PLATED STAINLESS STEEL RING MESH.
Anthony Ferrara
clothing and jewelry made with stainless metal mesh - Mansfield, MA, USA
A. You can use next solution (electrolytic colouring):
1 lit sulfuric acid
7,5 gm sodium bichromate
For 18 cr/8 Ni SS,object= anode,cathode=lead,70-95 C, 1,3 V , o,o6 A/dm2,5-5o min(colour sequence=brown, blue, yellow,redish brown, purple, green)
(according to Detner/Elze:Handbuch der Galvanotechnik [occasionally avail. from eBay, AbeBooks, or Amazon affil links], Muenchen 1963.)
- Zagreb ,Croatia
A. I think they make blueing solutions for stainless. You can also try baking lacquers. They come in different colors that can be baked in the oven at like 350-400degrees for a fairly permenant coating. and of course there is always heat coloring if your not worried about the temper.
Jason Aube
- Flint, Michigan
