PULSE PLATING AND ADVANTAGES
Hello....
I read a abstract about pulse plating at last week. I am very surprised about advantages.PC(Pulsed Current),DC(Direct Current),PR(Periodic Current Reversal) had been compared and interesting results had been found.According to this abstract in same current density,compare DC and PC ;to obtain thickness from PC,greater than DC.And most interesting;If you use PR in acid zinc,you needn't add organic additive even one gram.
Is this true this theory? Could you give me some explanations about this subject?
Thanks.... Sincerely....
Emre Tuna
engineer - Istanbul, Besiktas, Turkey
