Is There a "Rub-On" Brass Finish?
Hello,
I have 2 brass plated antique wall sconces and over the years the brass plate has rubbed off. I would be really grateful if anyone knows of a "rub-on" brass product that I could use to restore some type of brass finish to the metal. I would rather not paint the sconces, or go to the expense of having them replated.
Many thanks in advance,
William Johnshomeowner - Chicago, IL, USA
I know for only one rub on brass plating process. Immersion brass plating process also exists, but only cyanide based.
Rub on brass for zinc:
10 parts of saturated ammonium chloride solution
1 part copper carbonate
⇦ this on
Amazon [affil links]
Mix ingredients and rub it on zinc or zinc plated object(well degreased and oxide free!).
Goran Budija- Zagreb , Croatia
There is a wax based compound called Rub n Buff ⇦ this on eBay or Amazon [affil links] , that comes in many tints, and may serve.
