Stopping galvanic corrosion of dissimilar metals that must be electrically connected
WHAT WOULD BE THE BEST METHOD OF SEPARATION OF DISSIMILAR METALS WITHOUT REDUCING ELECTRICAL PERFORMANCE (CONDUCTIVITY BETWEEN MATING SURFACES)BETWEEN 6061-T6 ALUMINUM WITH CHROMATE CONVERSION COATING PER MIL-C-5541, CL3 AND BRASS OR COPPER?
DOMENICK SIGNORINOMICROWAVE FILTERS - EDINBURG, VIRGINIA, USA
First of three simultaneous responses --
A thin coat of electroless nickel on the brass part should not affect the conductivity too much. If it does, gold plate the brass part, or possibly only the contact face. This is a labor for masking vs cost of plating the entire brass part tradeoff.
James Watts- Navarre, Florida
Second of three simultaneous responses --
Virtually impossible to do. The fundamental requirement for galvanic corrosion is for there to be a good electrical path between the two metals so that the corrosion circuit can be made between the two metals. I would suggest you think about alternative metals. The only way you will prevent galvanic corrosion is by ensuring the metals do not corrode (i.e., keep them in a totally inert environment)
Third of three simultaneous responses --
If you need Microwave continuity and not necessarily DC continuity, use a 1/4 wave choke as you would in rotating joints.
Tom Gallant- Long Beach, California USA
