Finishing 316L welds and plates to mirror finish
I need to weld 316Ls/s plates onto 316Ls/s product bowl. The bowl has a mirror finish, what would be the best method to bring plates and welds up to mirror finish?
Hugh KearonMechanical service engineer - Cork, Munster, Ireland
How big are your plates and how many pieces do you have to finish? In lieu of that, maybe a typical low quantity production should be processed with a hand held grinder/wheel system using a non-woven on both the plates and the weld. You may need a smaller version for the weld area.
AF Kenton
